Mystery wire - need some help
talbotdd
OK guys there is a wire running along the firewall that apparently goes nowhere. It has a male end on it that looks like it should go to a harness but it is just hanging. It starts from a distribution block on the pass side firewall and ends at the drivers corner with all the wiring harnesses. I just found out it was disconnected today so I removed it from the distribution block until I know where it is supposed to go to.
Pics are attached:
Any ideas?
Thanks in Advance - without this site I would have gone crazy by now.
-Dustin
ircwet
Re: Mystery wire - need some help
Probably went to the light on the hood...I will post pics of mine
sy2206
I don't think anyone has pointed it out, but it looks like it's probably the wire for the hood light...
SY2932
Administrator
One end of the wire that powers the hood light. There *should* be a rubber cap around the end in the last pic that holds a fuse in there. Looks like yours is missing...
sy2206
Yeah, Mike is correct. There's a little rubber boot on the end, where the fuse sits in there. I have a complete OEM hood light w/ all the wiring and the boots on it if you need one....
