Re: my small project
Thinking today at work about my truck and what I have done in the year I have had it. And all the friends and help I recieved. I want to say Thank you to Roy, Chris, George, Mike, Jeff, Brandon and all the others for your help. Also would like to say RPM, JS, and Prime gears for the cool parts. These vendors Rock!
I made a list.
LS1 Brakes
L35 heads 2.02 1.60 ported with SS valves
Ported intakes
3"SS exhaust ATR
RPM stage 2 turbo
Typhoon side mirrors
Exhaust Ceramic coated
PLX 250 WBO2
Razor Alky
4L80E Built by Prime gears
TCI trans computer
Custom Gilbert
Custom rear shaft
JS converson Kit
2800 Bille stall
RPM A2A
B&M trans cooler
Silicone vac. lines
Volvo fan
fan mounting kit
Dc fan controler
52mm TB & air foil
ABS delete
RPM brake booster valve& hose
Braided fuel line
braided trans lines RPM
3 guage pillar
Greedy controler and boost guage
Dampner
billet pointer
edelbrock water pump
polished timming cover
edelbrock double roller chain
130A alt
Powder coated brackets Alt/AC
PS pump
Phill long 50# chip
3 bar map
50# injectors
10" kicker box
150watt amp
Datamaster
Heater core
MSD coil
Distributor
taylor wires
RPM valve covers
Front axles
Solid motor mounts
Zq8 box
Steering shaft
Roller rockers
pushrods
Oil pump
EGR delete
Phil smog chip :roll:
Thats all I can think of so far
Thanks for everyones help
