my injectors may not be firing
ggallin
my injectors are not firing? has spark and pressure to the fuel rail but will not run unless gas is put in intake.
RSpengler
Ghetto Fab Specialist.
Re: my injectors may not be firing
What all have you checked? Did you make sure the main injector harness is snug? Have you done anything with your ECM recently?
-Rob
ggallin
just for the hell of it i swapped chips to see if it would make a difference the truck started and ran for about 10 minutes then died. same problem spark and fuel to fuel rail but does not run.
SY2932
Administrator
If the chip is installed correctly, and you definitely have both spark and fuel pressure, your ignition module is dead. A bad ignition module won't generate a reference pulse preventing the injectors from firing. Part number is 1048-2827 (located under your distributor cap, BTW).
ggallin
Thanks that was the problem.
