Re: My budget LQ4/4L80E build! update, way over budget, 9's or bust!
Currently I am working on a CTS-V brake upgrade to replace my C5 front and stock rear brakes. Like most things I have done on this truck, I am going to do it the hard way. I am doing this after racing in a 1/2 mile event and realizing how terrible my old setup was for high speeds.
GOALS
- First gen CTS-V 4 piston brakes from and rear
-14" front rotors and 13.4" rear rotors
- Fit all of that under a 17" wheel for my drag setup
PARTS
- Brand new calipers purchased off of Amazon
- 2010 Camaro SS 14" front rotors, drilled/slotted
- C6 Z06 rear rotors, drilled/slotted
- Renzfab brackets and lines
The problem I am going to have now is that the Renzfab front brackets are made for Z06 rotors and the Camaro rotors are inset more towards the spindle. I did this to gain approximately 4mm of additional wheel spoke clearance. Dont know how I will fix that issue yet. Also, the rear brackets are made for a Ty. I dont know what the difference is between that and a Sy setup but I will figure it out. .
Fresh out of the box...
Brackets and lines complements of Mike...
Caliper painting kit with high temp Brembo stickers.... They will be red with black Brembo stickers.
And the old front brakes that were hating life...
So I know I will probably get some shit for this but how will I fit the 14" front rotor and 4 piston caliper under a 17" wheel.... Lots of grinding. I started that today and have got some good progress. I really wish I had a rotary table to be able to use the mill but this will have to work for now. Nothing like taking a 7" grinder to a brand new part.....
That is a terrible picture but it was getting really dark. Still waiting on my rotors to come in. Once they are in I will also look into modding Renz's bracket to gain another 1mm or so of clearance by bringing the caliper closer to the rotor. As of right now, I have the caliper bolted the spindle and have been test fitting the wheel as I continue to grind the caliper.
More updates on that tomorrow
