My budget LQ4/4L80E build! update, way over budget, 9's or bust!
eviltwin
"junkyard syclone"
Re: My budget LQ4/4L80E build!
i cant speak for other turbos but the seals in mine a metal. Its pushing the oil between the seal. I will take some video when the tune gets finished.
s_blazin
hmm well maybe mine were not metal. sounds like you should be good to go then.:tup:
eviltwin
"junkyard syclone"
ordered a new converter today. yank py3600 for a 4l80e :lol: i want it to boost alittle before i take off.
Ground Rat
I just saw this thread for the first time, and read it all. Good job on putting it together so fast! Don't let the jerks with nothing good to say get to you. I can't wait to see some track footage. :tup:
eviltwin
"junkyard syclone"
truck was running like crap yesterday. took a look today and found this
ordering new wires to go around the primaries.
Ground Rat
http://i41.photobucket.com/albums/e289/eviltwin_1987/securedownload-72.jpg
You might consider making your own custom set of wires. It is very easy to do.
Also, you might find a good set of sleeves helpful: http://store.summitracing.com/partd...0612&N=700+400384+4294845355+115&autoview=sku
eviltwin
"junkyard syclone"
i am having these 2 wires make by the same person i got my first wires from. should be here sometime next week
eviltwin
"junkyard syclone"
getting ready for the new converter
also pulled the pan to fix a small leak
took about 4 hours total
eviltwin
"junkyard syclone"
today i started my $15 junkyard hydroboost conversion
and made a 2wd poly tranny mount work with the stock tranny mount
Injected1
Hey Eviltwin I would like to congratulate you on your build. It is an amazing build and now that I have damaged my second motor and I never even made it to the track you have inspired me to do the same. I was wondering if you could help me through this build. To start I would like a list of the parts that I am going to need to start collecting. I have a lot of parts to sell first. I am picking up a 2004 Lq4 with 90k miles, CKperformance 4L80e, and Yank 3600. I am picking up the complete pullout for $1150 next week and I want to start collecting parts now to build this winter. I will be video taping the whole build for everyone to have for future use.
What were some of the more difficult parts of the build?
I have a great fabricator/mechanic that will be helping me with the build but I just did my first motor swap about 2 months ago so this is all new me, but I am sure that I can accomplish it.
Thanks for any help that you can provide and once again TWO THUMBS UP on an amazing job putting this together.
Thanks, Nick
eviltwin
"junkyard syclone"
got the converter in today. Will put it in this weekend and take the truck off the jackstands:D
cloneman315
was it easy to pull that pan with the front diff out?
eviltwin
"junkyard syclone"
Just curious about the specs on your converter.
Lock-up? Single/multiple disc,,etc. Cost?
Thanks
from there site, 258mm, Posi Lock-Up Clutch w/Kevlar Linings, 6 bolt mounting lugs , lightweight billet cover, 3400 stall, 2.30 STR. Single disc i believe. Cost was $850 shipped to my door. had it 8 days after ordering it
very easy. there is plenty of room. i could change the rod bolts if i wanted to.
eviltwin
"junkyard syclone"
all i got to do now i bleed my brakes from the hydro boost conversion and i can start driving it again :tup:
eviltwin
"junkyard syclone"
well i drove over and got it weighed today. with 1/2 tank of gas and me in it, it was exactly 3700#. so the whole swap added 80lbs.
im going to get an electronic boost controller and get the tune finished this week or the beginning of next week
oh ya, traction is now a major problem
