My budget LQ4/4L80E build! update, way over budget, 9's or bust!
eviltwin
"junkyard syclone"
Re: My budget LQ4/4L80E build!
havent really worked on it in the last 2 days. been busy with work:tdown: I did get the hood to shut with the alternator on. had to take out parts of the hood support and do alittle grinding to the alternator :)
yes there was a bolt on top of it before.
i am suppose to get my turbo tomorrow :roll: If it comes than i will finish the truck this weekend and take it to the tuner on monday or tuesday.
nello
Where you going for the tune? Locally? AWD dyno?
eviltwin
"junkyard syclone"
Nick from Newtech Performance in Hayward will be tuning it. We will be going to a different shop to use a AWD dyno.
eviltwin
"junkyard syclone"
i just finished cutting my grill. put it on and took a pic. looks just like the pics when it was just sitting on there
my power steering is still leaking too :tdown:
eviltwin
"junkyard syclone"
not sure if you figured it out yet but this should be for cruise
not yet. thanks. now i can cut that out.
know anything about the others. Im thinking one is to the washer fluid pump
JuStBlAzIN
The hose looks like its the one for your charcol canister, that should be right underneath where your oil cooler was.
The wire...looks like a connection for your lights, check to see if you fog lights work. I remember connecting it to the lights harness when i swaped out my harness on the typhoon.
eviltwin
"junkyard syclone"
all my lights work. ill just leave them there just in case
Black Knight
I Glow Therefore I am
In your wiring pics, the only things I can come up with are,
#1 pic: That is a connection that goes to the ABS module C111, the diagram lists it as White, Purple, and Black/White. So as long as the wiring is something close to that, because that is what the connector looks like.
#2 pic: It's very hard to see wiring color, but if I had to venture a guess it appears to be the 4 wheel antilock brake pump motor C146, Red and Black wiring. Or it could be for the windshield washer pump, which shows Pink and possibly Black. The deciding factor is which harness is it in. You have three harness coming out of the junction block on the firewall. If it comes from the medium sized one (the one with 10 connections) then it's for the windshield washer pump. If it doesn't and just ties into the larger harness during its travel, then it comes from the ABS.
#3 pic: My guess is cruise control also. Very difficult to see wiring color and position. If you can get a pic of the connector end also that will make it much easier as they almost all different from one another. That hose probably went to the cruise control also.
HTH
s_blazin
the hose and plug both go to cruise
eviltwin
"junkyard syclone"
thanks for the info.
Here is the truck still waiting for the turbo :rant:
nothing left to do
eviltwin
"junkyard syclone"
well the turbo came in so i did alittle work today.
will do the downpipe and intake tomorrow hopefully
eviltwin
"junkyard syclone"
you're gonna have a hot fender!
the 180 bend for the downpipe is tight so it will be like 2" away from any point of the fender. I will have to cut the inner part of the fender though. I would live to just run the pipe right out the side of the fender but my passengers might not like that.
JuStBlAzIN
I think this is one pimp setup. He is local to me, and i hope to check it out before i start my LSX swap.
As far as the comments, let it go man. READ THE TITLE... "my BUDGET lq4/4l80e build" Key word BUDGET!!! To each his own.
jasonpickett
Don't bash him for doing something he wants to do. It is his project. If it is wrong or gets messed up later on that will be his problem and he will learn from his mistakes. It is a budget build and somethies you have to do things the cheap way. Sometimes they work and sometimes they don't. If hot rodders back in the day were worried about not stepping out of the boundaries when building something where would we be today. So learn from your mistakes and build it the way you want. If he blows the engine up then that just gives him another reason to make it stronger. That is just my opinion. Try to have fun doing it.
MikeRenz
not stock
i've cleaned up the thread. Please keep this on topic guys. Enough bickering amongst the peanut gallery. Its Just a Six...enough mention of the thermal wrap. 4 times is more than enough for 1 thread.
