asmo
Sy #2918
Drove this thing daily for the past two years, then today I started it it ran for a couple minutes then just died. I was idling waiting for it to warm-up.
My first thought was fuel pump-today is a hot day pump has'nt been priming for a while,- when I first start it in the morning I have to turn the key on and let it build pressure, then it starts right up, if I just start cranking it it takes till 3-4 cranks to start.
I checked the schrader valve on engine no pressure with key on or off, has pressure when cranking- ie squrted out the schrader all over, but only during cranking.
I thought it should have pressure always at the schrader?
I put in 3 gallons of gas to see if my gauge had went out or if the pump would cool off and run,trucks still the same.
