MSD noise
i8av8
trying to clean up the engine bay so i relocated the MSD box to the glove box which also has the street/strip/psi/valet settings box. with vehicle running the MSD box makes noise. a quiet yet audible flutter. it's not engine noise that playes to the tune of the gas peddal, either. the MSD probably always makes this noise only we can't hear it because the engine has to be running and w/engine running the MSD noise gets flooded out~sounding almost invisible. am i correct or did i get the six (2 to the coil, 2 to the dizzy, power to the alt. just like it was before, and ground) wires fouled up?
have no a/c or heat so i went through the fire wall where the heater core use to be. piece of sheet metal takes it's place. drilled a hole through the sheet and placed a rubber boot so the edges don't ruin the wires. has plenty of room inside glove box and plenty of ventilation through the back of glove box so heat can not be an issue. no excessive heat from that area.
no driveability issues>drives fine just like it did before the relocation. just wanted to see if anyone has experienced this before? tia
warmpancakes
Re: MSD noise
if the noise it through the radio you can wrap the MSD box in foil, or buy a mallory box and have no noise
i8av8
Re: MSD noise
not through the radio>made sure of that one. i can live with the noise since it's not that noticeable especially w/radio on or w/windows down.
always on your game, guys thanx for the qwik replies!
