Z SKI
I need some help from the pros.
A few days ago I was removing the lower intake to head bolts on my motor to replace them with stainless bolts and studs. I noticed that there was old collant corrosion on the old bolts and in the holes. This told me that there was a leak in the front and rear of the manifold by the water passages.
I thought, no big deal as I have read that you have to use some RTV around those ports to insure a leak free seal. So I ordered a new set of intake gaskets so I could do it the right way.
This is when it starts to get interesting. As I was chasing the bolt holes in the heads I noticed that the oil that was sitting in a small crevice where the block, head gasket, and head come together in the front corners right below where the oil drain passage exits from the roller rockers portion of the heads was migrating through the head gasket and following it along and collecting at the bottom outside of where the head meets the block.
So did i interupt the seal there by removing the intake manifold which now lets a little oil through? Which could possible be fixed by putting the intake back on?? Or do i need to pull the heads RTV those areas or install new head gaskets??
The only thing I am scared about is that my motor has an o-ringed copper gasket and honestly I dont know squat about them.
Any help will be greatly appreciated. And I can provide pics if my descriptions suck:tup:
Thanks,
Thanks,
