Moog parts
spooldup
Super Member
What parts do i need to redo the front end? I am hearing ball joints, and two kinds of bars? How many of each do i need and what and where do i get them? Thanks guys!!
V6 Kompressor
To really rebuild the whole front end, you need 4 Ball joints (2 upper and 2 lower), 4 tie rod ends, 1 drag link assy, 1 idler arm, 1 pittman arm, 2 tie rod connecting sleeves, 4 upper A frame busings, 4 lower A frame bushings, If the shocks have some age or have appearance of leakage, change them out also. If the brake hoses have cracks on them, swap them out also...I use wrenchead.com or http://www.partsamerica.com or one of the many other online "Stocker" parts sources to check prices, ect...If you want to change over to the Poly bushings, now would be the time to do that also...I did forget to add a set of sway bar bushings on the list also. If you want all moog stuff, I can get you the part numbers for everything monday pm, if you want. Just tell me what is wore out or what you want to replace...Steve.
spooldup
Super Member
Whats good about poly bushings? The mechanic just said my insides of my tires are worn and all the grease fittings are blown, shocks are shot too. Should i just replace the whole front end?
Captain Morgan
Moderated User
Ok, been doing some research on Idler Arms and Pitman Arms:
Questions so far:
Idler Arm
MOOG K6251T
or
MOOG K6251
Pitman Arm
MOOG K6339 is this correct?
ParTyBoy
If I recall correctly all the "T" stands for is an upgraded/redesigned part... They usually cost the same... that's all... Originally read this from a SyTy list thread years ago...
4C FED
Absolutum Dominium
Questions so far:
Idler Arm
MOOG K6251T
or
MOOG K6251
Pitman Arm
K6251T & K6339
Yes, those are correct.
Those are the ones I have installed on my truck.
InvisiBill
Looking at the box tops for the ball joints I just put in my Sy, K5289 and K5208. Those part numbers are different from the ones listed on Jas' site, but they look just like the old ones, and seem to be working just fine.
