Modded 2000 LS1 Formula F/S
Vsix
2000 Hardtop Formula 70k miles pewter with WS6 Ram Air Hood black stripe TA rear hatch nice paint very clean in & out black cloth interior... Mods are ...Full bolt-ons- Scanmaster, Pacesetter coated headers,Kooks Y-pipe,Magnaflow exhaust,UD pulley,SLP lid,smooth bellow,PP TB 78mm,LS6 intake,30lb injectors,Katech tensioner,Comp Custom Nitrous Cam,NEW springs, locks,titanium retainers hardened pushrods,Timing chain,LS7 oil pump,160 T-stat,NEW plugs & wires,HSW Brute Force 78mm plate kit adj 75-150HP, ash tray switch panel, bottle heater, billet bottle bracket, custom purge, Racetronix billet 650HP fuel pump & hot wire kit.....Trans mods- has Yank 3600 stall Transgo HD shift kit NEW solenoids B&M trans cooler .....Rear mods- stock 10 bolt factory 3.42 gears zexel posi Alum driveshaft, MAC Alum support cover ...Brake mods- crossdrilled & slotted rotors ceramic pads ...Suspension mods- PA Racing K-member with upper & lower tubular arms, Hotchkis strut tower brace, UMI full length subframe connectors,UMI torque arm & relocation crossmember,UMI lower control arms & panhard bar,Sphon chromoly 1" rear swaybar, KYB sruts & shocks, 1.5" lowering springs with airbag......Wheels & tires Weld Draglites 15x3.5" & 15x8 MT Drag Radials
The car runs & drives EXCELLENT tuned by HSW.... Fully functional STREET car PA insp everything works cold AC, power steering & brakes, heat ect... $14,000 or best serious offer .....Partial trades considered
Accardi726 - Photobucket - Video and Image Hosting
Thanks Jim
215-669-1696
