MN/ND/SD SyTy/GN race gathering
Anthony
Re: MN/ND/SD SyTy/GN race gathering
I don't think our Ty is gonna be there. This minigate is not working nearly as well as I had hoped and it's leaned itself out to the point where it's taking crazy amounts of fuel to get the O2s above 900. Oh well, that's life in the syty world.
Sunni and Henry and I will still be there, though. We're gonna come up friday and hit the fargo zoo to see if we can't cure Henry of his fear of camels.
sy1907
SYCOTIC
Bring your damn truck. Mine ALWAYS runs like shi$, but i still bring it. You can just be in my club for the weekend!
Anthony
I've gone through all I can and I'm gonna give it another try tonight after it cools off. As long as I can get the O2s up, I don't mind running 10-12 lbs of boost. I'd just hate to go through all the effort of trailering the pile up there when it's running even more poorly than usual.
turbodig
I'm bettin' a wide-band and a bit of fiddling with the minigate will cover both problems.
When are you gonna get a better chance to test and/or fix some of this stuff.
Heck, I'd be really surprised to have 1 truck there that *is* running right.
Sounds like Paul is in for Sat/Sun., and a new local will be coming on Sunday.
Later,
Anthony
Later,
Trust me, I WANT to bring it. It got to the point where it wouldn't accelerate after 4000 rpm, just sputter and choke. So I swapped out the 75# injectors for the stockers and stock ecm and it now runs much, much better. It's got mostly 93 octane in it now as well. The only problem with the stock injectors is that they're at 110% duty cycle @ 12psi with this cam. I'm not sure that's something that can be fixed with anything but an alky kit or 50# injectors. The O2s are in the 930s with 1.8 degrees of retard, so it's runnable. I might run it just to see how much the stock injectors can handle before they fizzle out.
I don't suppose you have an alky kit or bigger injectors around there, do ya? I'll trade you some 75lbers and a modded ecm...:)
turbodig
Weather, for those planning to attend:
Sunny and upper 80s- low 90s. Both Days.
Hot, but there's ice at the track and nearby in town.
See ya there.
Dig
