sly dvl
Ya, it's got a Turbo
Re: melting fuse but not blowing it!!!
Remove fuse - make sure meter is on the highest amperage scale (usually 10) - make sure the black lead is in the COM pocket and the red lead is in the 10AMP pocket.
Insert leads in place of fuse and read.
With nothing turned on (cig. lighter, int. lamps or anything eles on that circuit) the amperage draw should be zero. Int. lights will draw 1.5 - 3 amps roughly, cig lighter willdraw nearly 10 so plug your meter in and watch the numbers. If you get over 10 amps right away pull the meter.
Flukes have a "slow blow" fuse in them so it won't pop instantly but if you leave it connected for 4-5 seconds and are drawing more then 10 amps through it it will pop the fuse.
I'll post a pic of the meter in a minute...
It's the best image I could find on short notice. Pulled it from one of my powerpoints...
[/IMG]
