Maybe bad ECM
tyson__91
Today i got in my Ty and was hard to start finally got it running and now its idling at 1800rpm and when you hit the gas it has a real bad dead spot also the boost guage is all over the place when you try to rev it up. Thanks for the help.
Re: Maybe bad ECM
Or the MAP came unplugged? IAC bad? Or somethin' else with the IAC system? Any codes?:2cents:
tyson__91
Re: Maybe bad ECM
I forgot to put in that when i use the paperclip and the light should go out and then flash 12 3 times. But when i do it the check engine light never goes out.
NecroWolf
lost marbles member
Re: Maybe bad ECM
well i know a new ecm from the parts store is like 75 dollars so if you got the money give it a shot i guess
tyson__91
Re: Maybe bad ECM
Brand new Ultima
But last night it ran perfect only thing i did was try to run my datamaster but i couldnt get it to work never started truck just with key on. Then few hours later i went to start it and it started doing all of this stuff. What else other than ECM could cause all of this stuff at the same time.
