master cylinder mounting bracket
Quickstop [UK]
Combating adversyty.
Does the prop valve bracket go between the mc and the vacuum assist or does the bracket go in front of the master cylinder towards the fron of the truck.
A) mc ¦ bracket ¦ vac assist
B) bracket ; mc ; vac assist
Anyone got a pic please? I think I have a different bracket as the lines are really tight from the MC to the prop valve.
TIA.
PPI Typhoon
DIY Madman
Re: master cylinder mounting bracket
I just put mine on and it fit better with in in between, but I figured that doesn't work right. I had to bend the lines a little to mount it the other way, but I think it belongs on the outside:
Quickstop [UK]
Just imagine the hydroboost as the vacuum booster.
Yup, got a hydroboost on mine. How did you get such a nice finish on your MC?
I feel that. My worry is that the bracket off the HB and the one off the prop valve on the stock truck is a little different and I have mixed up the two.
I'll see what I can do today. Thanks for the replies guys!
4C FED
Absolutum Dominium
I have a small powdercoater, so I coated it in chrome-something-or-other.
The only thing is I didn't like how my other pieces turned out after I applied the clear powder over the chrome so I didn't put the clear on the M/C. Without the clear, the finish is vulnerable to brake fluid.
