ls1 throttle bracket
A
amerimuscle99
Guest
What is everyone using for the throttle bracket? I am using stock trans and throttle linkage so I need it for both.
thanks
Norm
Re: ls1 throttle bracket
I used a lokar one. You will need one with two holes in it, one for the throttle cable and the other for the downshift cable.
A
amerimuscle99
Guest
Yes I understand that just need to see what brackets people are using or making. Just want to make sure I get the right geometry for he kickdown cable.
Norm
you can also use a factory gm bracket with the cruise control on it, but if I remember you have to cut and weld it to work for your transmission.
