Re: Lower manifold mod
You could say I assumed that things were machined.
Port matching is something I'm still curious about. I know what it means of course, just as to how it applies here with the tall Vortec heads and our low manifold. It seems to me at this point that the lower manifold ports never truly "match" the heads. That the mod just makes it so the manifold bolts up and covers the ports. Correct?
Unless you do a *lot* of material adding, you never really get a true match. There's always a bit of a "ski-jump" in the roof of the intake runner where you're blending into the vortecs.
However, almost any blending is gonna be better than leaving them alone. You end up closing off about 15% of the roof of the port by doing nothing, and there's a lot of flow up there in a vortec head.
Ideally, you'd build the runners up so you had a more gradual transition into the port. This gets complicated, since the injectors are in the way, and there's a limit on how much you can grind before you lose integrity on the bung. If you're really going whole-hog, you'd fill the runners in and put in new injector bungs that would raise the injectors slightly. This is past what most people really need.
The manifold pics E-rue posted (somewhere) were a very good goal of what to shoot for. Bear in mind, though, that this is gonna take a fair amount of time to grind.
