Re: Lower intake swap / Vortec head & cam install on stock bottom end
Lower Intake Test Fitment
I bolted the lower intake to the drilled Vortec heads with the 1203 gasket. It's not as bad as it looked, actually it looks really good. I won't REALLY know for sure until I get it mounted on the block and try to connect BOTH sides..
With the manifold/gaskets lined up like this...
The ports look like this...
Obviously the top doesnt match at all yet, but that's why I'm porting the manifold (see 1st page of this post).
The "GOLD MINE" Information - Swapping a cam without pulling the motor OR A/C
Boy this one almost stopped me dead in my tracks. I spent many hours searching and found practically nobody who had ever swapped a cam on an S10 with A/C and without pulling the motor. Jim (Leroy here on SyTy) says he did it about 10 years ago and I think that was the only person! I found something on
Crane Cams website about 4.3L S10s: "In most cases, a cam change can be made without pulling the A/C condenser." Sure wish they had elaborated! :roll: Gee, thanks for nothing..
Here's my new cam, held up as reference to show the condensor's interference:
Since the cam bearings are a precise fit, you can't just "cock" the camshaft sideways and sneek it out. Or at least, I certainly wouldn't/didn't try. If you try to pull the stock cam out, you'll get to about halfway thru the distributor gear and the dowel pin of the cam will be in the condensor fins, this is assuming you removed the rubber condensor mounts and have the condensor flush against the core support.
So after banging my head against the wall, at 4AM this morning I came up with the solution. Pull the condensor IN and UP, instead of trying to pull it BACK!
And now,
The Million Dollar Photo:
The above photo was taken just minutes
AFTER I got the stock camshaft out!!! WaaaaaHoooo!! :lol: :woot:
I got the condensor ready, and then used 1 hand to hold it up and 1 hand to slide the cam out underneath the condensor. I had at least an extra inch of clearance, no problem!
My elation was short lived however, when I found out I had nicked all the cam bearings!!
:roll:
The first 3 cam bearings all look like this. I can feel a slight spot with my finger tip. Obviously, I tried to be as careful as possible but with no room for a handle and trying to do it myself I clearly wasn't careful
enough. I did some more homework and it sounds like a handful of people with other cars have nicked their cam bearings this bad or worse and put it back together with their new cam and had no problems. So I'm thinking of just going with it and crossing my fingers. But open to any advice/opinions from those more knowledgeable than me! A friend suggested using some light scotchbrite cloth to lightly polish the high spots out.. I'd do it but I'm afraid of making the bearing worse than it is. Thoughts?
Now I'm officially half way done with this thing!
PS: I would certainly recommend pulling the motor to anyone who has the resources to do so! It would be a lot easier and probably less time after you factor in how easy it would be to do all the head bolts etc. and the timing cover/oil pan would be a cinch. I am not that fortunate however, so this post should be a nice guide for anyone else who can't pull their motor but still wants to do a cam swap.
