Exhaust manifolds, lower intake installed, valve covers, stock IC insulation
Ported Exhaust Manifolds
I finished porting the exhaust manifolds. I posted photos of that earlier, but here's a photo of what's got to be the most restricted area, the #1 cylinder. This is after I opened it up quite a bit:
Lower Intake Installation
I have to say it again - I was amazed how well the heads' new intake bolt holes lined up with the intake manifold now that the heads are fully torqued! The machine shop did a dynamite job. I told them to match it to the 1203 gasket, but if they had followed my instructions the manifold almost certainly wouldn't have fit (without grinding the holes :roll: ) I asked the machinist and he said "Well, we don't always do exactly what the customer asks
" He said they had an old LB4 head they matched the pattern up identically to.
I tried being cocky and avoiding the "oozing black tar" look of the typical lower intake manifold by going light on the bead, but ended up using too little RTV on the block "china wall". I had to pull it and re-do it :roll: ARP Thread Sealer on all the bolts, and per "Bezerk"'s advice: 2mm bead RTV around each intake port, 3mm bead RTV around each coolant port, on both sides of the 1203 gasket. I went 25 FT-LB torque (factory spec is 35) since there aren't many threads on some of the newly drilled intake bolt holes.
Stock Metal Valve Cover Mods for Vortec Heads
TurboTony tipped me off to the fact that the stock metal valve covers don't fit Vortecs properly unless you heavily bend the outside flange on the (4) outside corners of the covers (all the ones nearest the tires). He was right, without a doubt! Thanks Tony!
Here's everything installed!
I also replaced that gunked up stock oil drain rubber hose with some nice blue/orange silicone turbo oil drain hose from ATPTurbo.com (I had leftover from my Turbo Grand Prix). You can barely see it on the lower passenger side of the above photo.
Exhaust Manifold Installation
Man, these things are the worst to R&R. :tdown: If you notice on the photo of the ported exhaust manifold (above), the flange has a terrible sealing surface, even though I hit it with the die grinder. From the factory they don't use gaskets, so it's like this ring of rust formed around it that sealed it, and when I removed the manifolds, some of it fell off, and some of it remained permanently stuck to the head. The solution? Permatex Ultra Copper High Temp RTV "Highest operating temperatures for 4-cylinder, turbocharged or high-performance engines. The most advanced, high temp RTV silicone gasket available." (
http://www.permatex.com/products/au...mum_Temperature_RTV_Silicone_Gasket_Maker.htm) This is the only silicone recommended for use on exhaust manifolds. (The red RTV isn't, and it also isn't Sensor Safe). This stuff is also good for 700*F vs the red stuff 650*F. I put a thin film on all the exhaust manifold flanges. Also, I always had a nasty startup condensation water-leak out of the PT51 turbo-to-downpipe seal, so I used a thin film of the copper RTV on the downpipe and turbo-manifold flanges as well.
I also found out that once the belt tensioner comes apart, it's junk. (according to GM). Had to buy a new one.
Stock Intercooler Insulation
I cut up a Taylor TAY-2544 heat blanket and stapled the ends. I used part to reinsulate the stock driver's side motor mount, and here's how I used the rest:
I wanted some protection from the downpipe heat, but without the ugly looks of "aluminum foil", so I did just the bottom with some ultra strong 5# 3M double sided tape (who knows if it will hold under the heat). You can also get a good look at how I did my dual alcohol routing.
