Re: lower intake disassembly and diagnosis
Update:
I got some new 850s from eBay and did a bit more reading on here. I decided to install a set of used good GM lifters after reading about failures of the 850s and 875s. The 875s I removed had two very easily compressible lifters which should not happen unless they are bad. I read that a few people have had bad lifters and some time in syty chat convinced me not to use the 850s either – they are not actually made by GM.
Corvette Forum issues
I replaced the lower but decided to pull it almost immediately. I wasn't happy with the first install of my lower intake for two reasons:
1) I didn't follow the torque tightening sequence (didn't know there was one)
2) It looked like the coolant passage at the front dvr side was not sealed properly.
Sooooo..
I pulled the intake and replaced the gaskets and tightened it all correctly.
The torque sequence for the lower intake is:
FRONT PASS side: 11, 6, 4, 2, 8, 10
FRONT DVR side: 12, 5, 1, 3, 7, 9 (edit – I need to verify this – it’s in the service manual if anyone has one but I don’t have that here. PM me and I’ll update this post)
I did a comp test after I had adjusted all the valves according to the TDC E/I then BDC E/I adjust method. NB – stock lifters require 1 full turn past 0 lash. I was a bit nervous with that but I got 165lbs compression on number 1. :woot:
So I connected everything else back up and started the truck after fighting with the distributor for ages. (Dis gear upside down....
Got it in eventually...
Truck ran great! I had the valve covers off and could hear a ticking - dammit! I then got my engine stethoscope out and heard it coming from E/I #3. The lock nuts turned out to be loose so I adjusted them until the ticking stopped.
I think that it has gone! Problem solved!
I replaced the valve covers as well and found that I can remove the driver side without dismantling anything else so I can adjust as required.
Conclusion: The new 875s I got didn’t work 100%.
Interesting piece of trivia.
The Royal Flight in the UK for the Royal Family doesn’t fly with any brand new parts on the aircraft. Due to the mean time before failure curves, they take parts, use them and once they have been used for a period to make sure they haven’t broken immediately, they stick them in the Royal aircraft.
I imagine Obama and other VIPs do the same.
One to consider when buying used vs new parts. I’ve had bad sensors and now lifters straight out of the box…..
