lower blocks
justin949
i want to lower my ty with 2'' lowering blocks in the rear if i lower it will i have to get shorter shocks i want to get koni shocks
turbodog
Lowering with blocks does not change the relationship between the upper and lower shock mounts. The axle gets raised up off the spring mount, but the spring mount (and therefore lower shock mount) stays in its original position. So, stock shock length is fine
Bear Dog
Make sure you use extruded aluminum blocks and not the cast aluminum type. The cast ones break easiser.
Eric
