vortecfiero
this is a real puzzle
I used to get 10lbs of boost at 2500 with out problem and it would go higher if i let it.
I have been running with it set @ 5 lbs while I mess with other non related stuff.
now i cant get more than 3 lbs at any rpm and it feels soooo slow
here is what i have checked
I have checked for leaks on the compressor to the throttle body ditto for cylinder heads to turbine section.
the turbo itself has no play in the shaft and the blades on both the wheels are fine.
I eliminated the BOV incase it was leaking.
I pulled the pressure line to the wastegate actuator to allow max boost (to test the actuator).
Locked the waste gate arm in a closed postion
i am not using a waste gate solinoid or anything else.
even if it was running on 5 cylinders id still have more boost
fuel pressure seems unchanged on my autometer guage
I will run data master to confirm the boost guage reading tonight.. but im not getting my hopes up
i remember playing with controlled leaks once to see what the leak to boost loss ratio was...
this would have to be a fair size leak and im sure i would hear an exhaust leak because
my car is quieter than a stock fiero V6 (full sleeper mode) except at full throttle
any ideas ?
any ideas ?
