Can't seem to hold high boost so I pulled the line off the actuator from the intake and plugged it.
I should get max boost this way, correct?
OK, just did a little drive around the neighborhood (I didnt go over 81mph!)
Boost is peaking at 21 psi and dropping off to high 14's, low 15's.
My thoughts are one of two things...
1 - the turbo cant keep up with the air flow
2 - the internal gate is being pushed open by the exhaust and the actuator isnt strong enough to hold it back. (I do have it adjusted with some overlap and had to use a pair of pliers to get it on the pin)
My next step is going to be temporarily wiring the flapper down to keep it closed but looking for some additional thoughts before doing this.
