Looking for Stock WG
John C Holmes
Would it be wise to go with stock? My Ty is mostly stock. My WG is covered in rust. Not even sure if it works. Is the ATR one a direct replacement? Or should I consider a crossover weld-on? If anyone has a stocker sitting around cheap not covered in rust I might be interested. Just bought all new plumbing for down there as well. Oil return/supply/gasket and water return/supply and boost control solenoid. Turbo is in good shape bearings and blades that is.
thanks
Cody
kwick6
Are you talking about the actuator?
leroy
The actuator could be tested with a mityvac. It should retract when vacuum is applied and hold vacuum.
The wastegate arm should move freely. Sometimes this is hard to test since it may behave differently when hot.
Jim
John C Holmes
If you saw mine you would understand. It's rusty beyond anything. Plus it's so rusty its hacking up my lower radiator hose. Had to use some spare hose to protect the Goodyear hose.
kwick6
On 2002-01-26 08:37, TheGreenDruid wrote:
That's the one buddy!
Is that one for sale? Sorry I forgot the actuator.
Cody
That one isn't for a syty, but I'm sure if you post in the classifieds, someone might have one.
Scott
SyTyJedi
Jedi Council
thanks
Cody
The ATR wastegate sucks, and it will only work with their downpipe, which is pointless to use with the stock turbo.
If you want ROCK SOLID boost control, get an external on the stock crossover and a profec B or similar. It will never be a problem again. Spool is also insane.
