are these copies of the cbr kit? im first in line if so
X2 for me.
If you need any measurements for the C6 Z06 six piston caliper...here is my measurements. Bolt hole centers are 5" or 5.048.
The measurements that you requested for the C5 ( if you even need it ?)...is 3.40, pretty close ( since I don't have pads loaded yet)
I'll buy a set and deal with the offset if any and report my findings. What is the cost of these ??
Cheers,Vinny
Yes, these are front brake upgrade brackets.
I am not sure if I am going to put these into kit form or just sell the brackets.
I will put an ad in the classifieds when that time comes.
Also...what are the mounting ears eye centers for the calipers ?
5.025 between centers on the caliper side
Thanks for that spec.Well cool....I don't see why I'd have any problem mocking up the six piston calipers with some spacer adaptation R&D on my end.
PM me if you'd like to let a pair go.
Cheers Vinny
if you got spindle from a 98 up 2wd blazer I have different bracket for thatI would be very interested in these. Just curious, will these fit a 1st gen 2wd? I am building a LQ9 version. I am guessing these would let you use teh hubs from a newer (2001 up) blazer correct
