InvisiBill said:
You don't have to, but it won't hurt. Other turbos are cooled only by the oil in them. If you just shut off the engine, it fries the oil. Ours have liquid cooled center sections, so it isn't as important. If you just did a hard WOT run before pulling into your driveway, it might not be a bad idea to let it run for a bit to cool it down some more. But idling or a turbo timer isn't as necessary on these trucks as on other vehicles.
I may not own a sy/ty, but I do drive a car equiped with a garrett turbo with a water cooled center section. Just beacuse its water cooled dosn't mean that that you don't have to let the bearings in the turbo cool down. If I rember corectly the sy/ty has a mitsubishi heavy industrys 17g turbo charger, in wich case all mitsu made turbos are recomend to be "turbo timed" if you don't belive me just hop in a 1g(90-94) eagle talon, mitsu. eclipse or plymouth laser and flip down the visor, it says right there that you should let you car idle to cool down the bearings in the turbo.
If thats not enough for you, when I very first bought my car it had been driven by a girl for its entire life. You know what that means, no synthetic oil, no turbo timer, and no cool down
. The first time I changed my oil, chunks of coked up oil came out(think of small black gummy bears waving at you as the oil passes out of the pan). Sence then, I have not once seen any coked up oil come out(wich is proably do more inpart to the fact that I run Mobil 1 full synthetic than the fact that I let my turbo cool down). Its only 60 seconds, just pop in a good cd and listen to some tunes, while you do your turbo a favor.
