Do NOT use JB weld............pull it out and load the threads up with some black rtv.
Upon much closer inspection, it appears I have to other bolts holes leaking coolant. I took them out and they all seem to have something in common. It looks as though where the holes were drilled for the conversion that they drill in to the water jackets and there is only about 2-3 threads on 1/2 of the bolt hole. Im sure this sounds confusing but basically there is an "intrusion" hole in the drilled and tapped holes. I am going to try and let one sit over night and see if it works out. I sprayed some brake cleaner in there and dried it out best I could. So hopefully this will work. Is red better than the right stuff? Is there a better sealer I should be using for this situation?
My heads are the same Mike. Like I said I used the red RTV with no trouble with gasket sealer also. BUT somehow yur gonna have to figure out if, in fact, it's the bolt. What I'm wondering is if coolant is getting to the bolt above the threads from somewhere else which makes look like it's the bolt that's leaking.
I had the same problem when I put coolant in her Vortec headed engine just before I fired it up. I put white pipe tape on the threads and GMSI (GM sealant)/RTV and a flat washer.
No leaks since.
Hope that helps... It was the exact bolt your talking about.. Ironic huh.
~Scott
