Largest bore for a vortec heads
autoaddictions
Anybody know how big a bore vortec heads will support. Thinking assembling a bowtie block with vortec heads. Block is at 4.040 now might have to go to 4.050 or 60.
Icarus-54
Donating Old Member
Re: Largest bore for a vortec heads
Frank,I ran my vortecs on a .040 block with great sucess,I see no reason why you could'nt go .060 or maybe a little more.
Jack
autoaddictions
Jack
Block that i killed running 10.20 was 40 over.
I was waiting for you to chime in.. Thanks Jack
Raist103
99% sure the block in the garage i was running was .60
Icarus-54
Donating Old Member
I forgot Frank,on my old s-10 work truck,I ran vortecs with a 2114 intake and holley tb and that was 60 over.Put over 70k on it without problems.
5678TA
.020" is only another couple cubic inches. meaning <1% increase in engine volume. you wont be able to tell the difference. only downside i'd see is thinner cylinder walls and less shrouding of the valves.(not a bad thing)
as long as tolerances for everything are within spec, its just a freshened up motor. if you feel the vortecs are choking the motor, get em ported. but honestly, 1% more engine volume is only 1% more head flow needed.
Icarus-54
Donating Old Member
Looking over a set of vortecs,it looks a tho 80 over wouldnt be a problem on a bowtie block
It's just a six
Super Member
I would go close to max bore. Bigger engine, block will weigh less.
What is the max bore the block can take?
4.155"
This will give you a larger quench area, which can deter detonation, allow you to run more boost.
Maxtor
thats what i was looking for. did you use COMETIC head gaskets
Definitely. Mike Lee carries the 4.125" unless you have a local source. You probably already know this, but ensure your vortec's have hardened exhaust valve seats (especially when running larger than stock valves) or the heads will not be long for this world pushing bigger HP.
