L35 questions - now with pics
Loeryder
Re: L35 questions - now with pics
These are the L35s that Myclone so graciously hand ported for me...
This is the bowl and seat area after light blending and a once over polish.
Note the radius work left around the base of the bowl near the valve seal.
If you remove too much of that "Swirl" you will be causing more turbulence than increase in flow.
Opened up the backside all the way through the exhaust port.
We used a set of fel-pro copper gaskets to port match and then I made a stencil from the head and port matched my stock exhaust manifolds.
Intake ports he removed the casting and just rounded out the far corners.
Ports opened to match GM lower intake gaskets.
Chamber smoothed and polished.
It's not recommended to tamper with the area directly around the plug much unless you want to create hot spots.
These have screw in studs. the stockers have the shoulder.
No shoulder aftermarrket studs.
You will not fit a full bodied crane gold roller on that stud unless you have them drilled for the longer v8 studs and then they wont fit under the composite vortec valve covers without spacers.
So if you are set on 1.6's check out the roller tips. Summit actually has a nice set Jegs too.
Improvement over stock without a ton of machine work that would defeat the purpose of dealing with a budget head upgrade anyways.
clone 94
adam i have a set of complete low mile vortec's you should throw on there instead :D
SYO237
SyTy Registry
Jas, your referring to the stock bolt in studs like I have pictured?
Syclone #1721
I LOVE 4UM SUPERSTARS
In this picture, what keeps the rockers properly aligned on the valve stem tip??? There really should be a push-rod guide plate, no?
COMP makes self aligning Pro Magnums....I would hope thats what they are...Looking hard at the picture, it appears they are.
clone 94
those are self aligners, i have the aluminum bodied comp self aligners. its hard to see, but there are small SS plates on each side of the roller tip that keep them aligned on the valve stem
clone 94
sweet, i got some L35s....wanna trade? :p;):rotf:
lol why not :rotf:
if those are aftermarket studs, my bet is they are the 2.8 conversion studs, although i'm not sure if they would fit a stock rocker arm, because those heads were run with stock rockers
mystery heads lol
