...hey guys I did a search and couldn't find the answer to my question. I have replaced my stock heads with L35's on my 92' Typhoon. The heads have the have the screw in studs which are longer than the stocks; about a 1/4 inch longer. When I went to adjust the rockers in accordance with the repair manual, they seemed a bit tight and the valve appeared to not close all the way when manually rotating the motor. Did I miss something in doing this swap like using shorter rods or something?
