L35 head casting numbers need info
badas1
going to the junkyard to look for a shortblock to rebuild.anybody have some casting numbers and block numbers.what years did they come in full size trucks and s10.TIA
jwaller
Evil Genius/SyTy Guru
The L35's came in 94-95 trucks...they are easily recognized by the injector BUMP or notch in the top of the intake port...and most of the time they will haver screw in rocker studs...none of the early Heads have screw in studs...they SHOULD also have the plastci valve covers that say vortec
Richme
The casting number is 064, should be stamped inside the heads, normally junk
yards list them by screwed in studs or pressed in studs, you want pressed
in.
HTH,
