94c4lt1 said:3 really quick questions:
1. Can you tell me the location of the knock sensor (detailed)?
2. Any sites or locations with detailed schematics of a syclone engine or assembly?
3. Are there any good service manuals for a GMC syclone?
dgoodhue said:94c4lt1 said:3 really quick questions:
The KS is behind the distributor, as for good manuals get the Helms.
Loeryder said:nawwwwww
We got it out by taking the coil off and then having the Heather Tool reach all the way back there.
It is on the back of the Driver's side Head, the one with valves in it...
the KS itself has just a "nipple" on it and the single drk blue wire has a connector that grabs on both sides of the sensor and it can spin freely.
Get to the bottom edge and pry off one of the "legs" and it will slide right off.
cutting out during WOT
Loeryder said:cutting out during WOT
Cutting out like the fuel cutout and the truck just stalls?
Pull your codes, that sounds a lot like Overboost.
Adjust the wastegate rod..
Other reasons for not building full boost could be the vac lines at hte turbo.
There are 2 one from the compressor housing to the WG solenoid, and one for the solenoid to the actuator.
Look right on top of the turbo, those hard plastic lines and rubber elbows are probably quite brittle. replace them with some vac lines and zip ties and you're good.
