knock counts
Blitzspeed217
Hi.
I have bin looking for info on the knock sensor but havent found the bit of information i am looking for so i result in asking.
The info i needed was what should your knock count be at when you are in idle .Whats a normal reading .Thankyou :eek:
leroy
It's normal to get 0-5 knock counts while starting. Knock counts should stabilize after that.
HTH,
Jim
InvisiBill
Knock counts are how many times the knock sensor noticed something. Spark retard is how many degrees of timing have been cut out due to knock. 5 knock counts is hardly anything. 5 degrees of spark retard (also known as knock retard (KR)) isn't good.
Check/replace your ignition components. Use a piston stop to verify that your balancer isn't spun, then make sure your timing is set at 0.
leroy
The way knock counts are calculated vary. In other words, it depends on your scantool. Datamaster displays least significant bytes. Diacom displays most significant bytes. 256 knock counts on Datamaster would equal 1 knock count on Diacom.
On Diacom, I usually see 4 or 5 knock counts after startup. It stays there until I hammer it. I might see 2 or 3 additional knock counts then, and Diacom will show something like 7 or 8. Did that make sense?
HTH,
Jim
jwaller
Evil Genius/SyTy Guru
Blitzspeed217 said:
Boostedpimp said:
Blitzspeed217 said:
What about if the count stays at 5 dosent stabilize should i be worry. :cry:
Are you referring to Spark Retard or Knock Counts??
Knock counts.
knock counts only refers to the nuber or times the ECM has seen knock. it will only be a number that rises and will reset itself once it hits a certain number. counts dont mean that it's knocking "AT THAT MOMENT". but it does mean that it has seen knock in the past.
the important thing is that you have 0 knock retard. and you want 0 all the time. however that is like the holy grail. good luck in your quest.
jwaller
Blitzspeed217 said:
Thankyou all for your time and info.(Jwaller) my knock retard is at 0 at idle so far so good. :D
yes thats very good. now you need to see what it's doin in boost.
InvisiBill
Like Waller said, knock counts just indicate that there was knock in the past. 5 knock counts might mean it saw .1 degree of KR, or it might mean that it saw 10 degrees of KR. Knock counts basically just tells you that your knock sensor is working. It indicates that there was "something" and nothing more.
Knock retard is the important one. This tells how much knock there was. Ideally you want 0, but you are likely to see at least a little occasionally. http://invisibill.unimatrix01.org/sy/track3.uni is one of my passes down the strip. I have a little bit of KR at shifts and TCC lockup. On my graph, I have Spark Retard in red, TPS % in black, RPM in blue, and Boost in pink. If you do that, KR stands out, and you can easily compare it to your RPM to see if it's due to shifts.
