Rexxenexx
The key was stuck in the ignition today. I started the car and pulled it out of the garage, went to turn it off and it wouldn’t roll back. It’s stuck only able to turn forward to engage the starter. I put it back in the garage, pulled the ecm fuse and disconnected the battery.
When it was on (running), like I said, you could turn the key forward, turn the steering wheel, and shift into any gear. Just couldn’t turn the key back to turn off the car and get the key out. I tried shifting in and out of park. Jiggling in a gears. All I did just before was clean under the front of the engine, front diff, oil pan, trans pan, etc. Then check the lugs on the front wheels, put new o-rings on the wheel caps.
I have the tools to pull the wheel and I do have the random wipes after making turns sometimes. You think the problem is inside the column or should I check the shifter cable at some spot?
