johnson ICpump flow direction ??
dirtdemon
"mr. ghettowrench"
... is it possible that the direction of the stock-pump is the other way round ??
searched all sites (including this one ;) ) - help me bring it to the point please !!
what i know so far :
(stock setup) bottom of upperIC goes to bottom lowerIC (pump in between) and top of upperIC goes to top or lowerIC - is that right ?? ... or other way round - found both opinions on the board - and when i look at this i'm really confused :
*ARRRG* please gimme a hint :roll:
TIA,pat.
sy2675
He Saved the Pimp'n Game!
Re: johnson ICpump flow direction ??
Bottom to bottom doesnt sound right to me, but i could be wrong. have to look at the truck when i get home. Doesnt it make since to pump from the bottom of the lower to the top of the upper so that gravity can assist on the return path to the lower heat exchanger?
dirtdemon
"mr. ghettowrench"
ok - what can you guys see on the diagram above ??
... seems it's like sy 2675 mentioned or what ??
please be kind and gimme adive because of the flow direction ...
... the major Q is still on :
on the stock-pump, is the horizontal flange a sucker or blower ?
(... wow sounds porn, huh :rotf: )
TIA,pat.
Berra
On both the Jabsco and Johnson pump the
horizontal flange is a blower !
Berra
Johnson Pump Dealer.......
James Thomas
"NO CLASS"
You want to route your hoses so the the inlet flow for the upper is the "top" port and the out flow is the lower port to avoid sucking air in the upper I/C. The horizontal pump port is the outlet and usually has a arrow, unless this has changed on newer pumps?
________________
James
dirtdemon
"mr. ghettowrench"
my pump has an arrow, but it shows that the horzontal flange is the suction-side (vertical flange shows arrow towards outside) ... :dunno:
anyway, did my homework and made this (stock-setup) :
btw.: pump workie, IAT's ~50°C :cool:
... thanks for your time guys :tup:
regards, pat.
