Is this normal?
spooldup
Super Member
This is probably normal but i never noticed it before. Anyway i am driving the ty hard and it goes to 14lbs then shifts to the next gear and so on. So in between shifts the boost goes down then back up when the next gear grabs. I kinda remember the boost staying solid the whole time right?
Tooky
Serious about performance
Mine does that too but it goes down after the next gear has grabbed. I have stock turbo, stock wastegate. If you have a PTE turbo & wastegate then your boost control should be better. If you have an external wastegate then it should practically freeze the boost needle at your target boost and not drop until you let off the throttle. I saw a guy's DataMaster run with an external and his boost was a flat-line.
