Intercooler pump/flow help?
SuperSy
Re: Intercooler pump/flow help?
I think I almost got it. The truck maintained 108-110 in stop and go traffic, then was a steady 120 with 4-5 brief spurts of 14 lbs boost. It briefly spiked to 150 degrees at one point, but quickly settled back down to 120. I may try one more air purging session to see If I can improve it. I'm still getting 4 to 5 deg KR @ 14 psi, but still way better than before (8-12 KR).
turboj91
Super slow fill works too. Air can escape as quickly (althought it is really slow) as the incoming fluid and prevent air pockets.
Peter
my Ty and me 25+ years
If you actually are getting 4 gpm, that should be enough to clear air out of all the high spots and hoses. I actually measured mine with a flowmeter and 2 gpm (one Jabsco) is not enough, but 4 gpm caused a torrent of bubbles and completely cleared the system. My system has two heater cores in series with the stock upper and lower IC. It took two Jabsco (essentially stock) pumps in series, one in front of the lower IC and the heater cores, followed by the second pump that pumps directly to the upper IC.
sae
Found this on a search, but if anyone has this problem, squeezing both lines together for a couple minutes with cap open while refilling after big bubbles helps, and after a few top offs, put cap on and squeeze both lines simultaneously. I heard this from a friend and tried it out, started flowing like crazy in a few minutes. I'm running a Davies Craig 4gpm pump.
gmemony2
Resurrecting this thread...anyone have any new tips, or an easy one time solution to filling and removing air bubbles. Need to replace the pump and will be pulling off the heat exchanger to clean and check it out at the same time.
Edit: As a note, my lines will be running through passenger side fender, so not as easy to lift the intercooler, but I will still be able to to some degree.
2500avalanche
Well-known member
What I have done (with success) is take the TOP hose off, and fill it slowly. It will start to push the air out. Once it is filled, the fluid will start coming out of the rear of the upper IC, connect the hose, and fill it to the top. It always has worked for me this way. SOmeone years a go showed me (or I read about it)
gmemony2
Cool, I'll give that a try. Thanks
neildemo
Administrator
with aftermarket pumps like sureflos it doesn’t matter. But the gravity fed pumps on stock don’t like air in the lines. I could be wrong but what my experience has been. I also ran my lines through passenger fender.
Sy 0145
I am having the most difficult time purging air and getting good flow from the intercooler pump. I have converted the metal lines to rubber and ran them through the fender.What happens is I can drain and refill the intercooler and it will flow fine until the truck sits and cools down,thats when the problems begin. I made sure the drain hose from the intercooler was/is lower than the feed line to avoid trapped air. Could the weak stock pump be my cause?
I also installed a Ford lightning intercooler pump. It flows more than our stock pump and doesn't pull a lot of amps.
neildemo
Administrator
there was a write up here some time ago. Basically you pre fill the lower intercooler before attaching.
ChrisM
I tried this with no success still have air in system
ChrisM
Find any good ideas?
ChrisM
Anyone have any good ideas bone stock truck just replaced the dead oem pump with a Johnson and can't get all the air out
Sy 0145
Get a vacuum pump. It makes it easy.
Something that @neildemo mentioned, this pump is gravity based, the position of the upper intercooler, vs the lower is already good because the higher the position the more likely the air wants to travel upwards to escape. Elevating the upper intercooler further, by removing the mounting brackets, if you wanted to, and having it held up in the air while filled may also help remove the air bubbles trapped.
With the key in the on position and the addition of the bypass as @SY2455 mentioned, that should solve your air bubble problem. Without the pump running, what you're doing is manually moving the trapped air, and it seems, that is not as efficient as allowing the pump to do the work for you as it would with it constantly being on.
