Intake work
nightdiver said:
I finished with the upper intake and it looks like the one Dennis did
Good - did you do the welding yourself?
nightdiver said:
i guess a 10mm hole is good for the job
OK, specifics. It's not a crossover - that would be side to side. This is back to front. Basically the water flow is in through the bottom of the heads at multiple points along their length but they only drain from the front. Dennis taps the holes with 3/8" pipe thread diameter (1/2" would be OK) and runs 5/8 inch hose.
ParTyBoy
MikeRenz said:
Hu Ryde said:
Bless, clean that thing! Go have it tanked or sandblasted, it's only like 20 or so bux.
you shouldn't sandblast the intake....sand will remain in the thing to later be sucked into your engine.
beadblasting ownz you... :lol:
nightdiver
I didnt do any welding but i made it smooth
I gave a better look at your intake and i might do that overporting
0-60N4 said:
Can you post a picture of this "cross-over" plumbing? Sounds like a good idea.
I'll ask Dennis to take a shot or two of it. I know I've seen at least 1 picture of a SyTy engine built with the same bypass. Dennis also puts it on the SBC engines he builds.
