Installed Ultimate & 50# Inj. - now truck barely runs
ganja
Just got my Sy and it sounds like I may have a similar problem here.... The previous owner told me he added a chip or something but didnt tell me what it was. I will have to ask him on tuesday. At WOT the truck sputters and loses power, but when I barely give it gas it runs smooth. Its kind of a rough ride at all times... Is that bad? The exhaust is cut off short in front of the rear tire and makes the loudest sputtering noise when I punch it. I cant even launch right, some pontiac grand prix passed me up today and there was nothing I could do about it. :x
I suspect your truck is not running right, might have a BAD chip, KB or otherwise, and if your not careful, you will be asking about where to get a new engine, and syty's are garbage trucks.
Just what I see in the crystal ball.
Do yourself a favor, get a scan tool (datamaster and laptop is best), and start reading FAQ's, and doing searches.
A truck will shut it self down, if it is running bad, but it can only do so much.
kwick6
The best help your gonna get is by calling Sean, since we can't really walk you through it on here.
These trucks fuel supply is inadequate in stock form, much less with a chip.
And if I recall your in Cali, and probably can't get over 91 octane (except race gas). Be careful, and call Sean.
Your going to need a tuneup, now. CR42TS ACdelco plugs, and Conrad cap and rotor.
Lets keep the questions in the other threads that you started, so you can get the most help.
Later,
Scott
ganja
ok thanks kwick...
i can get 92 octane but its like 30 miles away. is it worth the 1 octane difference or should I just buy some of that octane booster in a can? also, I took the truck to jiffylube and had them change everything: fuel filter, air filter, oil (synthetic), radiator flushed, the works... I will go get the items you mentioned I need. lastly, who is sean and how do i get ahold of him?
thanks again...
HighPerformanceTrucks
Lift & Shift Specialist
I had a bad chip once causing the car to barely idle and stall, but I had it replaced with a functional one and everyone works great. If your not happy with the big injector setup, you can still run low 12's maybe high 11's with a stock injector Ultimate and the 3 bar.
Adam Auerbach
Sy#2419
Will_in_China
Truckless Wonder
mrweelr said:
rarebit - I just did the test with the ignition on and I get 2.3 volts with the 2-bar MAP and 1.6 volts with the 3-BAR so looks like both sensors are good. I'm not going to pursue this further until BG tests the Ultimate for me.
Just had a MAP sensor fail on a milehigh Ty. (Brad's)
No indications it was the MAP:
ECM didn't throw codes.
Tested ok.
Swapped it out, everything fixed.
Might be worth a try.
Anyone have one local you can try?
-Will
bdubb
I am teh kingpin!
SPiN said:
FastDubb said:
we should have Ryan's ty vs Spin's ty. this saturday at us41.. both oddfires, both were built about the same time. just different people built them.
(Sorry to go OT again...just saw this...)
How did I get brought into this? :roll:
Number one, it hasnt been even close to three years; number two, shit I just finalized my setup pretty recently (top end). Was doing one tranny then another, you guys know how tough that shit is, then decided to go different heads, then different this, then different that, suspension shit. So many different things...
When I am running, Ill go get timeslips. No talking shit, no childish bickering. I am completey happy with how meticulously my typhoon is getting worked on and amazed at some of the other stuff coming out of the shop. If I had a Typhoon because I wanted to make other people happy I would have sold it the first month I got it. I have it because I love it.
Not really looking for a response or starting shit here...just saw it and felt it warranted a quick response. Peace out!
pretty simple. ask mike. he said all the rockford trucks vs the chicago trucks.
sorry if i took the ASSumption. but hell, if rockford built my truck i wouldnt race it either. might break the crank, or somthing.
rdtyphoon
Whine Ass Bi*c*
Whine Ass Bi*c*
Everyone should just forget this guy since he obviously doesn't think he may have possibly made any mistakes. And he wants to keep crying about how his truck does not run right, instead of accepting it and trying to fix the problem. So let him figure it out if his install is so perfect then why does he need everyone else to tell him why his truck doesn't run.
0X
mrweelr
Up yours rdtyphoon :fist: How about I send you this setup and you bust your ass all weekend installing it. Then, when your truck doesn't run, let's see how you fix it bitch. BG is going to test the chip and we're going to proceed from there. Keep your derogatory comments to yourself.
TheObiJuan
Re: Whine Ass Bi*c*
Re: Whine Ass Bi*c*
0X
dude, this was dropped pages ago, we are now moving forward. he is making an effort to be civil and work the problem out.
i suggest you move forward aswell. :roll:
rdtyphoon
Well then it took him long enough. Hey everyone here is just here to give support and help. But if you complain and don't want the help, then too bad. But if he is trying to fix the problem through the right channels now, then good. And by the way wheeler :fist: right back at ya. But enough of the petty bull SH*T. Anyways hope you get your truck running.
GOOD LUCK
0X
mrweelr
Brian - I just shipped the Ultimate to you via USPS 2-day priority. Send me a PM when you get it.
Thanks
Richme
mrweelr said:
I have been away for a little while, and when I was on this BB I was not interested in this thread, for obvious reasons, it seemed like it was going nowhere, but I MUST respond to this immature child. I do regret and sort of apologize for my earlier post, BUT HE DESERVED IT.
Ah...the elusive RICHME. Jerk who lives in Carson City and never posts anything until someone has problems and then he jumps in with some snide remark.
As I told you BEFORE, you do not know me, and perhaps you should go look at ANY PREVIOUS posts I have ever made, FOR I HAVE NEVER MADE A SNIDE REMARK TO ANYONE, INCLUDING YOU, and you would have deserved A SNIDE REMARK. I spent hours researching all of your questions to me when you were a newbie, and never once did I suggest you do your own research. But when I asked you why you were posting all my answers/suggestions that I privately emailed you to the BB you became ballistic, and indicated I should, "Quit stroking your ego". So that’s what I get for helping someone who can’t take constructive criticism, just like I did in my post that I am responding to. You obviously have some real problems with people, good example, I have not seen an apology to either Mike or BG….. betcha can’t do it, cause it’s not in your behavior….you are too immature to respond in kind.
You can come down to Santa Clara anytime buddy and we can do it on my front lawn...big FUCK YOU!
Oh, that’s classic, how old are you, 30 going on 8 years old. Next you’ll be telling me, “You’re dad can beat me dad up”….lol….You seem to get even more immature the more you go on.
Tom Dowd, Mike Bridges, and the rest of the Bay Area Sy/Ty guys are nice people and we all get along just fine. You, on the other hand, seem to have beef with more than a few members on this board. That said, I think you need to just shut your mouth and mind your own business :fist:
The Bay area fellows are great people, I have no problems with anyone except Mike Bridges, and that’s personal. I could bring it out here, but what is the point.
BTW, what have you done for the SyTy community in the Bay Area? I was the first to hold 2 or 3 SyTy events at my house every year for years, with food, and refreshments at no charge to anyone, but I left that area and no longer able to do that. Tom Dowd who took over, since I couldn’t, puts on a great event. However, Gorden Jennings had the best SyTy event in the Bay area.
BTW, how did your Sy/Ty gathering turn out? I heard only like 5 trucks showed up, he he :eek:
Geeze, you get more childish the more you type. This HAN event WAS NEVER my event, I just happen to live here, and I just happened to provide a BBQ rib dinner to all attendees, and no cost to anyone…..’cept me. Oh BTW, we had over 20 people here for that day, unfortunately most did not have the trucks here, due to miscellaneous malfunctions.
Nobody stomped on anyone or put anyone down. You haven't seen a piss poor attitude...not even close. I'm just slightly frustrated with this chip and injector install. BUT, I will settle down and assume that we can get this sorted out and all will be good. So can Brian or Mike please tell me if PROM ID 01002 is the correct version for a stock motor Sy with stock turbo, manifolds, DP, internals, etc.?
Amazing that BG and Mike would EVEN respond to you let alone help you out with this childish behavior you seem to have.
Let’s see if you are man enough to apologize to Mike and BG??????????? I doubt you can do it, although I haven’t read the entire thread, so perhaps you did.
Flame on, this is the last of my posts on this thread, sorry to the rest of you.
Eluding
I also think that Mike and BG deserve a public apology for the way they were treated in the beginning of this thread.
They obviously have incredible character to help someone who abused them needlessly.
mrweelr
OK, here's an update on the Ultimate issues. Brian and I worked on this for several months and finally yesterday we got everything working. He reprogrammed the chip with the "stock injector" program (v.7) and I'm now running the stock injectors again. Result - truck runs faster than ever at T1-15 with 91 octane and alky injection. Today I'm going to try adding 5 gallons of Xylene to my tank and not using alky. I was getting up to 11 degrees of KR when I tested the truck yesterday with the new chip...not good. Going to use race fuel or Xylene from now on since the pump gas here in California is just unacceptable. So I never did get the 50# chip or injectors working right in my truck but I think I can go quite a bit faster using the stockers. Only variables that changed between running like total garbage and now were the Ultimate and the injectors. Next mods will be a 2800 stall converter, ATR headers, and PTE 52 turbo. I really appreciate Brian working with me and making things right...will definitely do business with him again :D And for those who bashed me saying my installation or tuning skills were the problem... :fist:
Mad Mike
SYCOSIS
Don't you think you should look into why your getting 11 degrees of knock before you add Xylene ? 11 degrees of knock is unacceptable with pump gas at stock boost levels. Sounds like a time bomb to me.
