Re: Injector removal
Ok, I just switch injectors, took 1hr from take out and put back, did
not have to take out the BT or intake.
Driver side easiest:
Romove the coil baracket and move the map sensor out of the way.
Then the fuel line into the rail and the 2 bolt holt the rail down.
Pop that biatch out and its done.
Passanger side:
I have a2a, i didn't have to take anything out, you would have to remove the upper ic.
Disconnect the injectors, temp sensor, boost solonoid and Ac harness and move it out of the way.
Take out the 2 bolt that hold the rail down and pop the rail off.
Took pic for you..
driverside
passenger
