injector question
asrnj77
..hard to swallow
I have an opportunity to get a good deal on some 009's and I've done a search and the concensus seems to be well if you're going to get 009's why not get 50's or 60's? The reason here is that I can get the 009's for a good price in excellent condition. My current injectors are stockers and although my turbo is only slightly larger than stock I figure why replace stock injectors with stock injectors.
My plan is to get a good chip or multi chip for the 009's with an option for alky and upgrade the fp, plus the afpr. Otherwise its basically stock with a rebuilt motor/tranny, cold air kit, atr aux cooler, plus atr cat back exhaust. Does this seem reasonable? It's not going to be a track truck just a quick grocery getter. Should I bother with the 009's?
Re: injector question
If your planning on doing you own custom programming (code $59) go for it. if you think your going to be buying an off the shelf chip for 009, stick with the stockers.
asrnj77
..hard to swallow
I haven't seen any new off the shelf chips anywhere....as far I've seen the only new chips are either from RPM or Nolan and appear to all be custom. Custom is probably what I'm looking for...haven't committed to the code$59 stuff yet.
Darin
I have a set of brand new MSD 50lb High Z injectors still in the bags for $200 plus shipping,
