Re: Injector question
you need a chip and look at the top "search"
I dissagree, I ran my 50#er's with no chip for about 6 months, It's not idealic, but it can/will work. If you get a AFPR (which you will need eventually anyways) you could turn down the FP and using a scanner/data logger you can get your mixture right.
But Warmpancakes is right, the CORRECT way to do it is install injectors/chip/AFPR all at the same time and then start tunning......
