Re: Ignition Timing - Need Help!
SeattleSy#1255 said:
after rereading your post and looking at your pics, i think some of you problems may not only be ignition related, but you still have the 14 year old hard plastic vacuum lines on there. Those things crack and leak, messing your idle up along with a million other problems, from performance to idle. Get some silicole vacuume hose and redo all those lines and i'd imagine your idle will be better. Something may be cracked.
Some of the pics are of when I first got the truck, as I am taking it apart. The pics of it complete show the all new vacuum lines...or maybe not so much because they are run so you can't see them anymore =P But...maybe I need to redo it over again because I still have problems?...
The timing has been set to 0, instead of 6 degrees advance. The fuel pressure has been set to 42 psi static (with no vacuum line hooked up), instead of 58 psi static. wtf?
Problems...
The truck still has a bad idle and is now slower and less powerful then before I changed it to the correct settings. The idle smooths out to almost perfect with the tan wire disconnected. As soon as you plug the tan wire in, the idle chunks along and the tach bounces maybe 20-50 rpm in the 600 rpm range. My dads van has the same motor and it idles perfect with 200k miles on it =( !!!!!!!
Can anyone verify that 42psi is the correct fuel pressure? this sucks =(
Thanks guys.
