Ignition problems again.....
jeremysyty
Typhoon running awesome last Friday night. Not missing a beat. Saturday morning go out to go pick something up. Truck won't fire. Turns over no spark. I threw the coil on another truck and it works fine. By passed my HI6S box and still no spark. Before I tear the distributor apart and see if it is the Ign. module or pick-up. Is there anything I have overlooked to check?
TIA,
jeremy
B
Blake
Guest
Your positive no spark? Could be no fuel also if a relay has gone bad or pump took a dive. Did you check your ecm-B fuse? This can cause the condition also if I recall correctly.
Just throwing it out there.
Blake
jeremysyty
Checked the fuses already. All good. Hear the Walboro fire up for the 2 sec prime. Put a old plug in my spark plug wire and no spark. Probably just the darn Ign module.
jeremysyty
Went out to the Ty last night to tear the distributor apart. Thought I would just give it a try. Started right up. Now I am even more puzzled. I love this truck :-?
