You might want to get ahold of David Syclone892, I think his username on here is Syclone892 or Syclone#892. He had that problem adn it was solved by an RF filter.
Try running without the MSD box once and see if that solves the datamaster.
Otherwise for the link timing you open up the ALDL Serial Data Acquisition window and do one of the menus, Setup or Options, it will have Advanced and like the bottom option under there says Serial Communications... once your in there, I think its the right most slider "Link Timing". Try changing it from 190-210 and find the beginning/end numbers where your laptop still connects to the ECM. Then set it to the MIDDLE of those numbers.
