IC Line Air Purge
Aeroking
e.i.
I switched my IC hardlines over to 3/4" soft lines last night. Filled my fluid, and ran my Johnson for about 15 minutes, and still no bubbles in the cooler box.
So, I must have air trapped in the lines.
I have my lines routed over my distributor, behind my brake reservoir, through the driver side fender, out under the remote oil filter, and down to the heat exchanger.
So about 2 feet of IC lines are above the top of the coolerbox.
Anyone with soft IC lines, do you have a relief fitting, or a capped Tee fiting to release any trapped air??
ppress79
Re: IC Line Air Purge
i unbolted the I/C and raised it high enough to purge the air w/pump running. No problem.
Phil
