IC Coolant Flow Direction
LuvBoost
I think my hoses might be hooked up backwards. If it's not filled to the very top of the tank it sucks air. Does the coolant flow from the pump to the cooler or from the pump to the tank?
Zac
I can't tell you the direction of flow, but:
If you look at the back of the Upper IC, the connection that is the highest one (closest to Intake manifold) get's connected to the Pump.
Chris
Daron
Try routing your lines same as stock, otherwise it can be terrible to bleed the air out.
The bottom of the CAC should be connected to the top of your CCHE, then the output of your pump should go up to the top of the CAC.
Daron
Re: IC Coolant Flow Direction
BTW, this thread really belongs in the "How to Mod" section. Might get a bit more help there....
LuvBoost
Yah, I should have stuck this in there. Sorry 'bout that! Anyway, everything seems to be hooked up correctly. Jacking the front end up helped get the air out. All is well now.
