Re: I Need Help, Please.
Thanks, let me give you my situation. I've not changed the AFPR, or the fuel pump. Matter of fact, the truck is stock save for a brand new ignition system including Distributor. Ok, with that. On the stock chip it runs great. Four 9.0's at the track. Now, with the 10n1 chip, in T1-16, or any setting for that matter, at 3,800rpm registered on Tach, it stutters really violently, then picks up to about 4,300rpm and does it again. Further, when I flog it, it hesitates just a little as if it wasn't getting enough fuel, or to much. Now, if I just hold it in second gear, at half throttle, and only say 5psi, let it cruise up to 3,800rpm, it still does the same thing. So I just don't see how it is a fuel issue. I've pulled the MEMCAL out, swapped it for another, turned it around(it then didn't run hardly), and I just happened to have a 3 bar Map laying around from my S/C Dakota, and so I put that on, and no difference. What else is there for me to do, especially based on the part throttle dieing of the motor at 3,800rpm? Am I just shit out of luck?
