Ian Turgeon
Cascading Inspiration
Ok, I've got a new noise and wondering if anyone can name that tune.
Keep in mind, truck runs great, drives great, shifts great.
The noise is a sort of grinding clunk
I can think of three situations it makes this noise.
1: tight radius turns at a parking speed (not always)
2: switching into reverse (not always)
3: switching off the motor, right as the engine stops rotating ( just started.. seems every time now)
This has been happening for about 600 miles, with #2 and #3 only starting in the last week. It sounds like a trans problem, but the thing absolutely drives fine and the fluid looks perfect (and its new).
my suspect list (some dont make sense in all cases):
TC bolts
engine mounts
fan clutch?
front driveshaft
loose exhaust
front diff
xfer case
trans internals
motor internals
IF this is an easy one please speak up, Im headed out to the garage and see i f I cant diagnose it...
TC bolts
engine mounts
fan clutch?
front driveshaft
loose exhaust
front diff
xfer case
trans internals
motor internals
