Re: I can't get felpro's into the 9's
It has a gas cap on it!
Yea I decided to give up on the felpros and went with a new set of cometics. I resurfaced the heads (they were pretty twisted) and I THINK I have the block straight. I used a chisel sharpening stone, a machinist straight edge and metal dye to smooth the block deck , and to make it flat.
From what I can remember, it was running really lean though too, and in the video you can hear it lose power and then the head gasket blows. I say 14.5ish afr's before it went, which won't knock but there isnt enough fuel going in to cool it down. I probably turned the ground strap into a glow plug. Next time down the track i'll richen it up a bit, and maybe pull timing down.
